7 months ago
08.10.2024, 04:06 GMT-4
I am not sure if I have the solution, but please try to use tertiary current distribution instead, that covers also mass transport. I would also round the corners in the geometry.
Convective transport is known to be a tricky problem to solve. As you certainly know, meshing is very decisive.
Good luck!
Good luck!
7 months ago
08.10.2024, 15:50 GMT-4
Thank you, Lasse! Your suggestion was very helpful. Removing the sharp corners helped and the simulation ran for a longer interval before convergence failure. It still puzzles me that the laminar flow physics problem runs fine even with sharp corners but fails when coupled with the secondary current distribution physics even though this contributes no coupling terms to the laminar flow physics.
My larger problem has coupling of secondary current distribution, transport of diluted species, and laminar flow which effectively is the tertiary current distribution with the supporting electrolyte option.
7 months ago
09.10.2024, 05:02 GMT-4
One more hint: add gradually the flow rate from zero to the target value, using auxiliary sweep below Study Extensions. That uses the previous solution as the initial value for the next. It helps quite often.
