UNDO
How to undo past actions in comsol 4.3a??
3 Replies Last Post 24.01.2013, 15:14 GMT-5
Posted: 1 decade ago 24.01.2013, 10:19 GMT-5
you have the "undo command", But given that some modifications triggers major node update actions hence the undo list is flushed regularly so you cannot really undo everything, but many things
Hi you have the "undo command", But given that some modifications triggers major node update actions hence the undo list is flushed regularly so you cannot really undo everything, but many things -- Good luck Ivar
Posted: 1 decade ago 24.01.2013, 11:09 GMT-5
How can I undo if anything is available??
[QUOTE] Hi you have the "undo command", But given that some modifications triggers major node update actions hence the undo list is flushed regularly so you cannot really undo everything, but many things -- Good luck Ivar [/QUOTE] How can I undo if anything is available??
Posted: 1 decade ago 24.01.2013, 15:14 GMT-5
In 4.3a you have the undo / redo icons (curved arrows), and or CNTRL-Z (if the undo icons are greyed then your buffer is/have been cleared
Hi In 4.3a you have the undo / redo icons (curved arrows), and or CNTRL-Z (if the undo icons are greyed then your buffer is/have been cleared -- Good luck Ivar
