time dependent study of the powder compaction model does not converge
Posted 13.07.2024, 04:12 GMT-4 Structural Mechanics, Physics Interfaces Version 6.1 0 Replies
What I want to do: I am studying the powder compaction example given by Bridget Cunningham on COMSOL blog posts. The blog post can be found here. It comes with a PDF description file and an MPH model file. They can be found here.
I want to simulate this model for a time dependent case when the powder is compressed linearly with time.
Changes I made to the provided model:
- Kept the physics definitions in the solid mechanics module the same.
- Created an interpolation function called disp_func and defined it to go from 0 mm at 0 seconds to 2 mm at 100 seconds.
- Then I created a variable called disp = disp_func(t)
- Then I defined the prescribed displacements to be -disp and disp on the top and bottom surface respectively.
- Added a time dependent solver. All the solver settings are given defaults except the output times are set to range(0, 1, 100).
The problem I am facing: The simulation stays stuck at 4% progress for hours. I don't understand what the problem is and how to address it. It looks to be quite a simple model with only one physics but it refuses to progress. Please give some advice on how to address this issue.
P.S. I cleared all built meshes and stored solutions when uploading the model file.
Hello Aurora Jahan
