Post Displacement Larger Than Length of Post
Hey y'all!
I've been working with a beam I designed in COMSOL and I have been applying some lateral forces to it to measure the amount of deformation in the beam. I am expecting a linear relationship similar to Hooke's Law for reasonable values, and also expect that the deflections will max out at very high forces.
However, when I use very high forces, I get extremely high deflections which do not make sense. For example, after applying 1000 micronewtons of force, I get a deflection larger than the size of my post which does not make sense. Can someone explain why this is the case?
Thank you!
1 Reply Last Post 10.07.2024, 03:15 GMT-4
Posted: 5 months ago 10.07.2024, 03:15 GMT-4
You are probably not including non-linear geometry, so 1 N will just give you 1000x more deflection than 1 uN, as everything scales linearly. Otherwise, upload your case.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Reply
