Vibration of a cantilever beam
I am trying to model a beam oscillating under external vibration condition.
I have kept one end of the beam fixed. I have tried applying different kind of boundary conditions to solve the problem.
1. applied accelaration (10m/s2) on the fixed end and did the freq domain analysis.
2. applied accelaration (10m/s2) on the entire structure and did the freq domain analysis.
but i did not get the expected displacement of the beam.
can anyone suggest what would be the appropiate boundary conditions and analysis method for such case?
3 Replies Last Post 18.01.2013, 01:52 GMT-5
Posted: 1 decade ago 17.01.2013, 15:43 GMT-5
the vibration load aspect is not trivial, you can either define a gravity = body force rho*a (a=acceleration) applying onto your model, with one boundary fixed, or add a "large Mass" object that can slide onto which you apply a force of given F=M*a with a the acceleration.
But the transfer functions are not exactly the same. Check the Forum, it has been discussed a few times
Hi the vibration load aspect is not trivial, you can either define a gravity = body force rho*a (a=acceleration) applying onto your model, with one boundary fixed, or add a "large Mass" object that can slide onto which you apply a force of given F=M*a with a the acceleration. But the transfer functions are not exactly the same. Check the Forum, it has been discussed a few times -- Good luck Ivar
Posted: 1 decade ago 17.01.2013, 16:22 GMT-5
Thanks for your response.
I have indeed applied body load (i.e. g*acceleration). But my question is to get appropiate solution, what kind of study should I do? Should I apply the body load in the form of a sinusoid and do time dependent analysis with t defined for more than one time period (1/first eigen freq)? Is that correct or any other kind of simulation setup is needed?
Thanks in advance.
Hi, Thanks for your response. I have indeed applied body load (i.e. g*acceleration). But my question is to get appropiate solution, what kind of study should I do? Should I apply the body load in the form of a sinusoid and do time dependent analysis with t defined for more than one time period (1/first eigen freq)? Is that correct or any other kind of simulation setup is needed? Thanks in advance.
Posted: 1 decade ago 18.01.2013, 01:52 GMT-5
I would propose harmonic development (frequency sweep swith a constant force amplitude (or a frequency dependet if you want to scan a PSD (power spectral density) distribution)
Hi I would propose harmonic development (frequency sweep swith a constant force amplitude (or a frequency dependet if you want to scan a PSD (power spectral density) distribution) -- Good luck Ivar
