Flow Induced Noise
Joseba Martinez Lopez
I am modelling a multiphysics problem: the typical flow around a cylinder which creates a vortex street street behind the cylinder. This vortex then acts on the cylinder structurally speaking. I have coupled the laminar flow with structural mechanics and it works perfectly.
Now, my question is, can I couple this with acoustics to see how all of this affects acoustic waves? From what I've seen, it is only possible to couple it with LES.
Thanks in advance,
Joseba
1 Reply Last Post 01.07.2024, 13:36 GMT-4
Mark Cops COMSOL Employee
Posted: 9 months ago 01.07.2024, 13:36 GMT-4
Updated: 9 months ago 01.07.2024, 14:05 GMT-4
Modeling flow-induced noise requires modeling the turbulent pressure fluctuations which are the source of the noise itself. This is not captured by laminar flow. In COMSOL, flow-induced noise can be modeled, as you mention, by using LES and Lighthill's acoustic analogy. You may have already seen this model, but this is the tutorial model available for flow-induced noise: https://www.comsol.com/model/cavity-flow-noise-105021 . Please note the LES part is quite challenging in terms of convergence, computational resources, and data storage.
-Mark
Modeling flow-induced noise requires modeling the turbulent pressure fluctuations which are the source of the noise itself. This is not captured by laminar flow. In COMSOL, flow-induced noise can be modeled, as you mention, by using LES and Lighthill's acoustic analogy. You may have already seen this model, but this is the tutorial model available for flow-induced noise: https://www.comsol.com/model/cavity-flow-noise-105021 . Please note the LES part is quite challenging in terms of convergence, computational resources, and data storage. -Mark
