Sergei Yushanov
Certified Consultant
14.01.2013, 14:21 GMT-5
Ray,
Use the following steps:
1. Options>Functions
2. Click New
3. In the New Function window, define function name, click Interpolation radio button, and select File from Used data from selection list
4. Click Browse button to locate file with your data for refraction index.
5. Click OK
Sergei
Ray,
2. Click New
5. Click OK
Sergei
14.01.2013, 15:06 GMT-5
Thank you so much! You made my day :)
14.01.2013, 16:23 GMT-5
I have another question: I defined two functions: n and k, which are the real and imaginary parts of the refractive index. The complex refractive index is expressed as: n+ki. How do I use n+ki as a variable? I tried n+ki, n+k*i, n-i*k, none of them worked. Comsol simply doesn't recognize the combined complex number. How do I combine these two functions into one complex function and use it in Comsol?
Thank you.
Thank you.
Sergei Yushanov
14.01.2013, 16:43 GMT-5
Ray,
Under Options>Global Expressions, define variable
complex_n=n(lambda)+j*k(lambda)
and use variable “complex_n” as needed anywhere.
If you need real part of this variable, then real(complex_n)=n(lambda).
Similarly, imag(complex_n)=k(lambda).
Sergei
Ray,
Sergei
14.01.2013, 16:57 GMT-5
Thank you, Sergei. It worked. You are so wonderful! :)
