ERROR: FAILED TO EVALUATE VARIABLE JACOBIAN, Variable: Freq
I am getting the following error:
Failed to evaluate variable Jacobian.
- Variable: freq
- Geometry: 1
- Domain: 1 2 3
- Feature: Stationary Solver 2 (sol2/s2);
- Error: Failed to evaluate variable Jacobian.
I perform a frequency domain study (Study 1: Frequency Domain) and I calculate the electric field inside a solar cell (due to the 'light') with an 'Electromagnetic Waves, Frequency Domain (emw)' node.
The divergence of the Poynting vector:
div(S) = (d(emw.Poavx, x)+d(emw.Poavy, y)+d(emw.Poavz, z))
is then used for a second study (Study 2: Step 2: Stationary 2), via a function G = div(S)/hf, where h and f are constants. In the second study the drift-diffusion model for semiconductors is implemented and G is the generation term used in the 'Transport of Diluted Species' reaction term.
WHEN I try to calculate Study 2 I get the previous error. There must be some problem with the expression of div(S). However I can plot div(S) without any problems.
When instead of G = div(S)/hf I use another expression that does not include div(S) the simulation converges.
I have already tried to obtain a smooth electric field (Study 1: Frequency Domain) by selecting a Cubic discretization and very fine mesh (not in the attached model), however I cannot improve the situation.
Do you know how to fix this problem?
Thanks in advance for the comments
6 Replies Last Post 16.01.2013, 15:33 GMT-5
Posted: 1 decade ago 14.01.2013, 07:54 GMT-5
just a small correction, not included in the model:
div(S) = abs(d(emw.Poavx, x)+d(emw.Poavy, y)+d(emw.Poavz, z))
just a small correction, not included in the model: div(S) = abs(d(emw.Poavx, x)+d(emw.Poavy, y)+d(emw.Poavz, z))
Posted: 1 decade ago 14.01.2013, 08:31 GMT-5
Samuele,
Define global parameter “freq=c_const/lambda_1” and re-run Study 2.
Sergei
Samuele, Define global parameter “freq=c_const/lambda_1” and re-run Study 2. Regards, Sergei
Posted: 1 decade ago 14.01.2013, 15:33 GMT-5
Thanks a lot. That works! :-) Do you know why? Is that a bug?
Posted: 1 decade ago 14.01.2013, 16:09 GMT-5
Kind of bug.
See Ivar's explanation
www.comsol.com/community/forums/general/thread/33767/
Kind of bug. See Ivar's explanation http://www.comsol.com/community/forums/general/thread/33767/
Posted: 1 decade ago 15.01.2013, 00:53 GMT-5
I find it rather logical, that COMSOL defines only required variables when needed. But OK when you combine several solvers, what is needed by the first is not necessarily required by the second one. COMSOL is a GUI upona programming language so some rules must be learned ;)
Hi I find it rather logical, that COMSOL defines only required variables when needed. But OK when you combine several solvers, what is needed by the first is not necessarily required by the second one. COMSOL is a GUI upona programming language so some rules must be learned ;) -- Good luck Ivar
Posted: 1 decade ago 16.01.2013, 15:33 GMT-5
Thanks both :-)
Thanks both :-)
