adding wavelength to waveguide
please help me,i am new in comsol
I want to add wavelength to waveguide. i know the wavelength that i use. but i dont know in which field i enter the wavelength.
3 Replies Last Post 14.01.2013, 11:10 GMT-5
Posted: 1 decade ago 14.01.2013, 05:57 GMT-5
It is not clear what you want and what you need. You must provide more information on your model and your goal.
Cheers
Edgar
It is not clear what you want and what you need. You must provide more information on your model and your goal. Cheers Edgar
Posted: 1 decade ago 14.01.2013, 09:47 GMT-5
Hi Edgar
Thanks for your response
I design a waveguide that material of the core is Er:Ta2o5 and the substrate in top and bottom of it, is sio2
in the article that i want to simulate we have pump power and signal power, i want to calculate the gain, i think at first we should add the pump power and signal power,but i dont know how can i do that?
please help me Edgar if you work in this field.
Thanks in advance
Hi Edgar Thanks for your response I design a waveguide that material of the core is Er:Ta2o5 and the substrate in top and bottom of it, is sio2 in the article that i want to simulate we have pump power and signal power, i want to calculate the gain, i think at first we should add the pump power and signal power,but i dont know how can i do that? please help me Edgar if you work in this field. Thanks in advance
Posted: 1 decade ago 14.01.2013, 11:10 GMT-5
so you want to model a LASER process. Sorry this is far from my work and to be honest I doubt that it is possible in COMSOL in a straightforward way.
But maybe somebody can correct that.
Cheers
Edgar
Hi, so you want to model a LASER process. Sorry this is far from my work and to be honest I doubt that it is possible in COMSOL in a straightforward way. But maybe somebody can correct that. Cheers Edgar
