calculate the radius of curvature in 2D model
Tesfaye Tadesse Molla
Dear colleaugues,
I was looking for ways of calculating the radius of curvature of a deforming boundary in 2D model (in time dependent solid mechanics module).
i tried to use the equations derived for two fucntions of time i.e. u = u(t) and v=v(t) ,
Rad of curv = ((ut^2+vt^2)^1.5 )/(ut*vtt +vt*utt)
but this equation give me very noisy values which are bad for my solver. do u have any other suggestion to deal with this kind of problem?
Thanking you in advance
1 Reply Last Post 21.12.2012, 09:56 GMT-5
Posted: 1 decade ago 21.12.2012, 09:56 GMT-5
the noise comes from your higher order derivatives, try increasing the discretization order by "1", and use fine time steps.
Anyhow this has been discussed a few times on the Forum the last 2-3 years, so if you search you should find back the explanations on how to ;), I do not remember like that
Hi the noise comes from your higher order derivatives, try increasing the discretization order by "1", and use fine time steps. Anyhow this has been discussed a few times on the Forum the last 2-3 years, so if you search you should find back the explanations on how to ;), I do not remember like that -- Good luck Ivar
