Add gaps along a parametric curve
Posted 17.02.2024, 18:01 GMT-5 General, Geometry Version 5.6 2 Replies
Hi folks, we have an parametric curve with the follow settings:
Parameter: Name: Minimum: Maximum:
Expressions: xw: yw:
The curve is sweeped with an rectangle 1x4mm width/height to build a flat spiral and is divided into two work planes parametric curve/rectangle.
Now we would like to add a 1mm gap every 15mm along the entire parametric curve, and if possible also keep the shape/size.
We hope someone here can help us..
