volume within a closed isosurface
Hello
WIthin a 3D domain containing closed isosurfaces, is there a way to calculate the volume of material contained within each isosurface?
Many thanks
Dan
3 Replies Last Post 07.12.2012, 02:58 GMT-5
Posted: 1 decade ago 05.12.2012, 01:18 GMT-5
if you define an integration over a domain, and use the Bolean operand "(My_Var < My_value)" I would expect to get the total volume of the region obeying the Bolean condition, no ?
In COMSOL a 3D integration is by default: integrate_over_my_selections_of_Domains(argument*dx*dy*dz)
while the dx*dy*dz is "implicit" (or it might be 2*pi*r*rd*dz in 2D axi)
Hi if you define an integration over a domain, and use the Bolean operand "(My_Var < My_value)" I would expect to get the total volume of the region obeying the Bolean condition, no ? In COMSOL a 3D integration is by default: integrate_over_my_selections_of_Domains(argument*dx*dy*dz) while the dx*dy*dz is "implicit" (or it might be 2*pi*r*rd*dz in 2D axi) -- Good luck Ivar
Posted: 1 decade ago 07.12.2012, 01:25 GMT-5
HI Ivar
Thanks I hadn't thought of using a boolean expression.
Works perfectly of course
Thanks again
Dan
HI Ivar Thanks I hadn't thought of using a boolean expression. Works perfectly of course Thanks again Dan
Posted: 1 decade ago 07.12.2012, 02:58 GMT-5
one warning, do not use Boolean on average operators, as the normalisation is not taking into account the boolean expression and you get too low values. Then its worth to write out the two integration fully, both with the same boolean expression in the numerator and de-numerator of the average expression
Hi one warning, do not use Boolean on average operators, as the normalisation is not taking into account the boolean expression and you get too low values. Then its worth to write out the two integration fully, both with the same boolean expression in the numerator and de-numerator of the average expression -- Good luck Ivar
