Sergei Yushanov
Certified Consultant
29.11.2012, 10:54 GMT-5
Roman,
Permanent magnet can be created as following:
1. Use Magnetic Field, No Currents (mfnc) interface
2. Create geometry for magnet surrounded by air
3. Create material for air (by default all domain will be selected as air, which is OK)
4. Right-click “Magnetic Field, No Currents” node and select “Magnetic Flux Conservation”
5. In the “Magnetic” settings window, select your magnet domain in the Domain Selection section
6. Locate “Magnetic Field” section, and choose “Remanent flux density” from the “Constitutive relation” selection list
7. In the “Remanent flux density” edit window, define Br vector components. If your magnet orientation is North-South, then define vector as Br={0,0,Brz_value}
Good luck,
Sergei Yushanov
Roman,
Good luck,
Sergei Yushanov
Andrea Ferrario
COMSOL Employee
29.11.2012, 11:13 GMT-5
Roman,
All the models in the Model Library have a PDF file with step-by-step instructions on how to recreate them. In the AC/DC Module there is a model called permanent_magnet that can you may find useful.
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Roman,
Andrea Ferrario
COMSOL AB
30.11.2012, 00:54 GMT-5
Thanks Sergei and Andrea!
10 years ago
09.07.2015, 02:23 GMT-4
Dear Sergei Yushanov,
I have a doubt regarding the implementation of the physics of my device in comsol. I have tried manier times to simulate it but failed. Can you please give your valuable time to look into this problem and tell me how can i simulate magneto-electric simulation in comsol. kindly see the attached doc in which problem is discussed.
my email id is
sachindhariwal16@gmail.com
my email id is
