Can shell unit link with solid unit directly?
I want to calculate the eigenfrequency of the sturcture below (in the attachment),but I am not sure whether the model I built is reasonable, can anybody help me check it ?
(I use shell unit in above plate and solid unit in the middle part)
2 Replies Last Post 28.11.2012, 22:19 GMT-5
Posted: 1 decade ago 28.11.2012, 09:56 GMT-5
Conceptually linking the shells to the solids should not be a problem. You should constrain the displacements of the shell to be same as those of the solid at the same location. What’s harder is accurately constraining the shell rotations.
Nagi Elabbasi
Veryst Engineering
Conceptually linking the shells to the solids should not be a problem. You should constrain the displacements of the shell to be same as those of the solid at the same location. What’s harder is accurately constraining the shell rotations. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 28.11.2012, 22:19 GMT-5
I am so thankful for your answer,but how to make the displacement of shell the same as solid in the same location?
And I have another question, does the surface using shell unit present the middle surface of the thin plate?
I am so thankful for your answer,but how to make the displacement of shell the same as solid in the same location? And I have another question, does the surface using shell unit present the middle surface of the thin plate?
