Why do the stress results differ from same model and same situation?
Hello dear scientists, Hope all is well! I have a very simple model,just a steel box.The fixed constraints are all at the bottom, and the boundary load is applied externally with a pressure of 0.1MPa. The only difference between the two is the positive pressure+0.1MPa in the figure above and the negative pressure -0.1MPa in the figure below. It is reasonable to say that the stress values calculated by the two should be the same. Why is there a slight difference in the actual calculation? One is 229MPa, and the other is 223MPa. https://img1.imgtp.com/2023/10/10/Ats8aFuf.png https://img1.imgtp.com/2023/10/10/g2p1A1Nw.png
2 Replies Last Post 11.10.2023, 21:28 GMT-4
Posted: 2 years ago 11.10.2023, 05:50 GMT-4
If the stresses differ with only a sign change in the load, then there must be some nonlinearity in action. Is geometric nonlinearity activated?
If you increase/decrease the load by, for example, a factor of 5, what happens to the stress values?
Henrik Sönnerlind
COMSOL
If the stresses differ with only a sign change in the load, then there must be some nonlinearity in action. Is geometric nonlinearity activated? If you increase/decrease the load by, for example, a factor of 5, what happens to the stress values?
Posted: 2 years ago 11.10.2023, 21:28 GMT-4
DEAR Mr Sönnerlind: Thank you very much for reply,and your suggest really helped me,it works,the stress values become to the same,whatever the factor changed or not,they're linearity now. I just didn't notice that the default is nonlinearity in Comsol,and the most important thing is I didn't realize that nonlinear calculations would be affected by sign change, I should learn more about nonlinear theory. Thank you again. Best regards.
>If the stresses differ with only a sign change in the load, then there must be some nonlinearity in action. Is geometric nonlinearity activated? > >If you increase/decrease the load by, for example, a factor of 5, what happens to the stress values? DEAR Mr Sönnerlind: Thank you very much for reply,and your suggest really helped me,it works,the stress values become to the same,whatever the factor changed or not,they're linearity now. I just didn't notice that the default is nonlinearity in Comsol,and the most important thing is I didn't realize that nonlinear calculations would be affected by sign change, I should learn more about nonlinear theory. Thank you again. Best regards.
