Boundary Load Change Having No Effect
Hi !
I'm having the same problem as this thread. (https://www.comsol.com/forum/thread/95741/Boundary-Load-Change-Having-No-Effect) Jeff has given an answer, but the link he posted is currently not working.
As for me, like the thread's question, no matter how much I change the current load, only the same amount of change appears. It is the same whether the load is set to 0.01 N or 1000 N.
1 Reply Last Post 25.08.2023, 12:24 GMT-4
Posted: 12 months ago 25.08.2023, 12:24 GMT-4
Updated: 12 months ago 25.08.2023, 12:27 GMT-4
See this other thread.
Bottom line: the solution is in fact different. It looks the same on screen because a different scaling is applied. Just refer to the numbers on the side of the colorbar when you plot the von Mises stress.
Jeff Hiller
See [this other thread](https://www.comsol.com/forum/thread/274932/thermal-expansion-problem?last=2021-01-13T20:25:37Z). Bottom line: the solution is in fact different. It looks the same on screen because a different scaling is applied. Just refer to the numbers on the side of the colorbar when you plot the von Mises stress. Jeff
