Stop Joule heating and start cooling.
Hello, I am trying to simulate Joule heating model in Comsol multiphysycs heat transfer module. I want to use joule heating till the 19 sec. After 19 I want to stop JH and continue convective cooling till 240 sec. For the moment I just did joule heating to 19 sec. Tried to use 2 step solver but it doesn't obtain. If anyone can help me I will appreciate it. Thank you !
2 Replies Last Post 12.11.2012, 14:14 GMT-5
Posted: 1 decade ago 11.11.2012, 19:00 GMT-5
Multiple steps should work but is not necessary. You can change the heat source to be its original setting times (t<19.0). That expression evaluates to zero at times greater than 19.
Posted: 1 decade ago 12.11.2012, 14:14 GMT-5
one thing to add: if you run a standard, single, time series then be sure you have two ranges of time steps, so that you restart with small steps from t>19 and increase them the thereafter.
As well as using an "intermediate" or "strict" time "stepping" as you might see the solver will take larger steps after somw 10-15 sec and then miss somewhat the transient of you stopping the Joule heating at t=19
Hi one thing to add: if you run a standard, single, time series then be sure you have two ranges of time steps, so that you restart with small steps from t>19 and increase them the thereafter. As well as using an "intermediate" or "strict" time "stepping" as you might see the solver will take larger steps after somw 10-15 sec and then miss somewhat the transient of you stopping the Joule heating at t=19 -- Good luck Ivar
