Henrik Sönnerlind
COMSOL Employee
1 year ago
09.08.2023, 05:11 GMT-4
There are some effects of temperature that you need to take into account:
- You need a new set of fatigue parameters measured at the current temperature.
- You may want to take temperature dependence of other material properties, such as Young's modulus, into account. At elevated temperature, it is probably the yield stress that is most important (in case you are in the LCF regime).
- You may need to take thermal expansion into account. If the temperature is homogeneous, there are no stress gradients from the stress distribution itself, but depending on the boundary conditions, thermal stresses may be introduced in the structure.
Henrik Sönnerlind
COMSOL
* You need a new set of fatigue parameters measured at the current temperature.
* You may want to take temperature dependence of other material properties, such as Young's modulus, into account. At elevated temperature, it is probably the yield stress that is most important (in case you are in the LCF regime).
* You may need to take thermal expansion into account. If the temperature is homogeneous, there are no stress gradients from the stress distribution itself, but depending on the boundary conditions, thermal stresses may be introduced in the structure.
