Using domain probe value to derive other expression
Oluwafemi Akinmolayan
I am stuck with this. Let's say i have a domain probe variable as "dom1" with the expression acpr.pt. When i compute the model. I can see the values in the table log.
However, when I try to use the "dom1" variable to evaluate other expression in the derived values, it outputs NaN. I wonder if there are other mean to assigned variable name to probe in post processing results.
Please help.
1 Reply Last Post 15.08.2023, 04:33 GMT-4
Posted: 2 years ago 15.08.2023, 04:33 GMT-4
Under Domain Probe you should be able to select more than just pressure, but I would need to see the file. Note that with domain comes some integration or average or similar, so the actual value might not be telling you that much. When I just tried it, I could evaluate acpr.v_inst without any problem, so perhaps you are not entering the variables correctly.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
