04.11.2012, 08:54 MEZ
I'm not sure I understand fully your question, but in the model library example, one imposes a displacement on the top plate , hence to estimate the Force due to the stress a the plate level one must integrate the stress in "z" over the plate surface which is (2*pi*r*stress) wherer 2*pi*r is the 2D-axi loop length.
Now the aspect of water content is, from my understanding not included herein, as we need then to consider porous media and 2 component medias, this is not my domain, so for that you would need to get help from some geophysicist used to soil measurements.
I had to look up what a triaxial test is, I found already some reasonable explanation on Wiki
Nagi Elabbasi
Facebook Reality Labs
05.11.2012, 03:39 MEZ
The extra axial loading stress calculated in this example is the average stress over the top surface since the stress is not uniform. That stress is mainly proportional to the deviatoric stress (that’s why you subtract the Pxc term).Effect of water content and water pressure is not accounted for in this material model.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
06.11.2012, 06:09 MEZ
Nagi Elabbasi
Veryst Engineering
The integral operator intop1 is used for calculating the resulting strength over the whole soil sample. Since 2D axisymmetric conditions are used, integrate the z component of the stress tensor at each Gauss point times the circumference’s length: 2πr.
It is mentioned in the explaination that the axial stress is " integrate the z component of the stress tensor at each Gauss point times the circumference’s length: 2πr". what is the meaning of Gaussian point. Does it mean that the distribution of axial stress on the top plate is assumed as Gaussian distribution?
[QUOTE]
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
06.11.2012, 06:49 MEZ
no the Gauss points are a specific way to average your element results fron the node values, check the doc, and then you integrate this stress in [Pa] to get the total force, normal to your plate (and you use "z" because the plate is normal to "z", else you would have need to use a scalar product
