How to Use Solutions from Previous Study as Initial Conditions
Posted 23.10.2012, 17:57 GMT-4 RF & Microwave Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 4.3a 1 Reply
I'm trying to perform two RF simulations on the same model, but with two different sets of material definitions. The goal is to run a simulation on the first model and then use that solution as the background field in the second model. So far I have made two versions of the models differing only in materials.
I am having trouble "accessing" the solution from the first model. I have tried using both one study and two studies. When using one study I was expecting mod1.emw1.Ex would be the field from the first model, but COMSOL gives an error. When using two studies, I haven't found been able to find the correct syntax to access a stored solution.
Does anyone have any advice/leads on how to overcome this issue.
1 Reply Last Post 24.10.2012, 01:01 GMT-4
