A negative value of J integral before cracking
Hi all, I wonder if you have ever got a negative value when computing the J integral? In structure mechanics module, I add a thermal strain which can evolve with time. In this case, the J integral is a negative number. It seems that the thermal strain affected the computational process. Any solution to this problem?
1 Reply Last Post 22.05.2023, 07:50 GMT-4
Posted: 2 years ago 22.05.2023, 07:50 GMT-4
The derivation of the standard path independent J-integral makes use of the fact that the stress tensor is divergence-free. This rules out (most) body loads, as well as thermal strains.
A correction term (a surface integral) is needed. You can find an expression for this term (Eq. 26) in https://www.researchgate.net/publication/200092866_Numerical_Aspects_of_the_Path-Dependence_of_the_J-Integration_in_Incremental_Plasticity .
Henrik Sönnerlind
COMSOL
The derivation of the standard path independent J-integral makes use of the fact that the stress tensor is divergence-free. This rules out (most) body loads, as well as thermal strains. A correction term (a surface integral) is needed. You can find an expression for this term (Eq. 26) in .
