Inserting Nodal Data from a Surface Plot in COMSOL
Hello COMSOL research community,
I am trying to insert nodal data from a surface plot into a new COMSOL model. I have already exported the nodal data from the original model using the "Export - Plots in Results" functionality in COMSOL. The nodal data represents a 2D surface plot with co-ordinates and intensity values.
My question is how can I insert this nodal data into a new COMSOL model? Specifically, how can I assign a variable to this data and use it to define material property in the new model?
I would appreciate any suggestions or guidance on how to accomplish this. Thank you in advance for your help.
Best regards, Nived
2 Replies Last Post 13.04.2023, 17:07 GMT-4
Posted: 2 years ago 13.04.2023, 14:40 GMT-4
Hello Nived,
Is there a particular reason for exporting the data from one model file only to import it into another, rather than performing the entire analysis in a single model file? It is the easier way to go, when possible.
Jeff Hiller
Hello Nived, Is there a particular reason for exporting the data from one model file only to import it into another, rather than performing the entire analysis in a single model file? It is the easier way to go, when possible. Best, Jeff
Posted: 2 years ago 13.04.2023, 17:07 GMT-4
Hi Jeff, Thank you for your reply.
I am currently working on a stationary study of the mfnc module in COMSOL. My goal is to insert different material properties, specifically different BH curves to different nodes, in a single domain. These different material properties are a result of a previous model of the same geometry and mesh. My idea is to extract the nodal data of the particular variable representing the BH curve and re-insert this into my materials. As the BH curve is different at different locations, each node would represent a different BH curve. Ultimately, I need a material which has different BH curves at different locations.
However, I am uncertain if this is possible to achieve in COMSOL. Can provide guidance on how to implement this? I appreciate any input or suggestions on this topic.
Best Regards, Nived
Hi Jeff, Thank you for your reply. I am currently working on a stationary study of the mfnc module in COMSOL. My goal is to insert different material properties, specifically different BH curves to different nodes, in a single domain. These different material properties are a result of a previous model of the same geometry and mesh. My idea is to extract the nodal data of the particular variable representing the BH curve and re-insert this into my materials. As the BH curve is different at different locations, each node would represent a different BH curve. Ultimately, I need a material which has different BH curves at different locations. However, I am uncertain if this is possible to achieve in COMSOL. Can provide guidance on how to implement this? I appreciate any input or suggestions on this topic. Best Regards, Nived
