jkh
vsdgv
3 Replies Last Post 11.10.2012, 04:05 GMT-4
Posted: 1 decade ago 11.10.2012, 01:04 GMT-4
I believe you should consider a Definition model coupling mapping or projection operator to link your periodic domains, or perhaps there are an "antisymmetric pair" option in CFD, newer checked
Hi I believe you should consider a Definition model coupling mapping or projection operator to link your periodic domains, or perhaps there are an "antisymmetric pair" option in CFD, newer checked -- Good luck Ivar
Posted: 1 decade ago 11.10.2012, 03:55 GMT-4
kfmf
kfmf
Posted: 1 decade ago 11.10.2012, 04:05 GMT-4
Check for Model Coupling under Definition in v4 and check the Projection and mapping operators, + doc
For your case inflow = outflow on other boundary you need to inverse the sign of the components, w.r.t up/down boundary, that's all ;)
Hi Check for Model Coupling under Definition in v4 and check the Projection and mapping operators, + doc For your case inflow = outflow on other boundary you need to inverse the sign of the components, w.r.t up/down boundary, that's all ;) -- Good luck Ivar
