2 years ago
23.03.2023, 01:50 GMT-4
I have attached a doc file that contains my doubts with images.Please go through it and suggest me some solutions.
Thank You
Thank You
Henrik Sönnerlind
COMSOL Employee
2 years ago
23.03.2023, 11:04 GMT-4
The local coordinate system in the Fluid node is only used to interpret the inputs (that is, Velocity Field and possibly a nonisotropic Thermal Conductivity).
If you want to transform the velocity into a local coordinate system, you can use the Vector Transform node, found under Definitions -> Variable Utilities.
As for your second question, it is better if you can upload your model (or a similar one).
Henrik Sönnerlind
COMSOL
The local coordinate system in the *Fluid* node is only used to interpret the inputs (that is, *Velocity Field* and possibly a nonisotropic *Thermal Conductivity*).
If you want to transform the velocity into a local coordinate system, you can use the *Vector Transform* node, found under *Definitions* -> *Variable Utilities*.
2 years ago
27.03.2023, 01:47 GMT-4
Thank you for your kind suggestions.
I have used the vector transform node like you suggested. But unfortunatley I still get results in x,y,z coorinates. Can u please where I made a mistake?. I have attached the images.
Henrik Sönnerlind
COMSOL Employee
2 years ago
27.03.2023, 11:19 GMT-4
a) You have not selected any input in Vector Transform. You should select the velocity vector there.
b) The result to be displayed is the variable created in Vector Transform; a name that you choose.
Henrik Sönnerlind
COMSOL
a) You have not selected any input in *Vector Transform*. You should select the velocity vector there.
b) The result to be displayed is the variable created in *Vector Transform*; a name that you choose.
