2 decades ago
12.02.2010, 01:53 GMT-5
From what I read, my first reaction would be to say "Yes", and to compare the results, perhaps in steps starting with smaller loads to follow the on-linear the trend.
And, in anycase I can only suggest that you also do a couple of simplified hand calculations to check that your results seems correct.
19.08.2010, 15:44 GMT-4
Hi Ivar,
I that case are you saying that the large deformation on is mainly used when the results are non linear?
Assuming that I have a pre-stress condition that will linearize the results should I still use the Large Deformation on?
And lastly, in my condition if I have a circular membrane of 8 micron thickness and a 1 mm radius and clamped at the circumference, should I still set the large deformation to be on or off? I am still new at this and the manual does not seem to suggest on how shall I deal with this issues.
Hope that you could help in this matter.
Hi Ivar,
20.08.2010, 02:01 GMT-4
for me (in my understanding) I use large deformation for non-linear effects to get the cross elements 2nd order of the deformation in the calculations (see the structural doc)
but if I have a doubt (and in anycase wile setting up my models I work first WITHOUT large deformations as it's much quicker to solve) I run a "large deformation" case at the end, just to compare my results, in case of large diferences, I investigate further
8 years ago
13.04.2017, 03:18 GMT-4
I would like to ask , set the large deformation switch where? or how to set the large deformation of the vertical cantilever beam?
Thank you in advance!
