Effect of temperature on SAW devices
I'm trying to simulate the effect of temperature on Surface Acoustic Waves (SAW) devices . I'm using the module "Piezoelectric devices" and so I get the response of the admittance in a certain range of frequency. The problem is that when I modify the substrate temperature there is no change in the response of the admittance. Can someone help me with this? It should include more modules in the simulation? Thanks
2 Replies Last Post 03.09.2013, 19:15 GMT-4
Hello Sergio Mora
Posted: 1 decade ago 19.07.2013, 09:45 GMT-4
Hi Sergio,
I am having the same problem. I read somewhere on this forum that frequency domain analysis doesn't work for Heat transfer physics. And a suggested solution was to do a time domain analysis and convert the results in frequency domain by using necessary Fourier transforms. This is probably not the best solution but managed to give me some results.
Hope it helps. Please let us know if you've found an alternative to this method!
Anurag Dhutti
Hi Sergio, I am having the same problem. I read somewhere on this forum that frequency domain analysis doesn't work for Heat transfer physics. And a suggested solution was to do a time domain analysis and convert the results in frequency domain by using necessary Fourier transforms. This is probably not the best solution but managed to give me some results. Hope it helps. Please let us know if you've found an alternative to this method! -- Anurag Dhutti
Posted: 1 decade ago 03.09.2013, 19:15 GMT-4
hi
I am trying to model a Surface acoustic wave device using Comsol 4.3b.
I want to obtain the real and imaginary part of Y11 admittance in frequence response
thanks
hi I am trying to model a Surface acoustic wave device using Comsol 4.3b. I want to obtain the real and imaginary part of Y11 admittance in frequence response thanks
