Taking time for the meshing
Logeeshan Velmanickam
I am trying to do a microelectrode array simulation. Where the micro electrode structures are in the micro scale and the array size is 2x1 cm scale. When i do the mesh, it takes me more than 3 days and it hangsup. I am using a 30GB i7 machine for this simulation purpose. When i tried to upload the .mph file, i failed to compress it to 5Mb even after following all your guidelines. Could you please help me to do this simulation.
Thank you.
2 Replies Last Post 15.12.2022, 12:07 GMT-5
Posted: 2 years ago 15.12.2022, 04:23 GMT-5
Do you have to simulate the entire array? Can some sort of preiodicty BC be used to minimise the model complexity?
Posted: 2 years ago 15.12.2022, 12:07 GMT-5
Two possibilities: (1) your problem is too big for current computers or (2) you are not meshing efficiently. If you can't mesh it you sure can't solve it.
Look into using periodicity and/ or symmetry. Look up the Comsol tutorial on meshing.
Two possibilities: (1) your problem is too big for current computers or (2) you are not meshing efficiently. If you can't mesh it you sure can't solve it. Look into using periodicity and/ or symmetry. Look up the Comsol tutorial on meshing.
