Which module is required for induction heating?
Hello Friends,
I am doing simulation on induction heating process in which,
I need to apply all required finomina on induction coil and with the help of coil, I need to heat up the steel plate.
I have license of AC/DC module.
Please can any body tell me that whether the Heat Transfer modul is required to doing this pursuit?
Thank you in advance.
3 Replies Last Post 25.09.2012, 12:09 GMT-4
Posted: 1 decade ago 25.09.2012, 00:05 GMT-4
If you don’t have surface-to-surface radiation, conduction in shells, or other “advanced” heat transfer features you will not need the heat transfer module.
Posted: 1 decade ago 25.09.2012, 03:04 GMT-4
Thanks for your answer,
Actually I want to know the heating area which is affected by induction coil with respect to time and simulate the process to get the heat in less time for given object.
Could you please tell me that, for this pursuit which physics I need to apply in AC/DC module or in Heat transfer module?
Wating for reply,
Thanks.
Thanks for your answer, Actually I want to know the heating area which is affected by induction coil with respect to time and simulate the process to get the heat in less time for given object. Could you please tell me that, for this pursuit which physics I need to apply in AC/DC module or in Heat transfer module? Wating for reply, Thanks.
Posted: 1 decade ago 25.09.2012, 12:09 GMT-4
Hi Chirag,
I can’t tell from just based on the description you provided. I suggest you contact Support. For example, if the temperatures are relatively high you will need to account for internal surface-to-surface radiation which is only in the Heat Transfer module. Also if you have natural convection, without the Heat Transfer module you can input the convection coefficients manually, and with the Heat Transfer module you get them pre-programmed.
Nagi Elabbasi
Veryst Engineering
Hi Chirag, I can’t tell from just based on the description you provided. I suggest you contact Support. For example, if the temperatures are relatively high you will need to account for internal surface-to-surface radiation which is only in the Heat Transfer module. Also if you have natural convection, without the Heat Transfer module you can input the convection coefficients manually, and with the Heat Transfer module you get them pre-programmed. Nagi Elabbasi Veryst Engineering
