Can I disable or delete the boundary zero flux subnode?
Posted 19.09.2012, 11:45 GMT-4 1 Reply
I am solving for the magnetic field (g) inside a resonating microwave cavity using mathematical module physics. I use a coefficient form PDE of the Helmholtz equation inside the domain and a boundary weak contribution to specify the tangential boundary condition while letting the normal component of g be a free parameter. A default boundary zero flux subnode is constraining the normal derivative to zero which is incorrect. I can't disable or delete the subnode and I would need to specify either Dirichlet or Neumann boundary conditions for the normal component of g if I was to override the zero flux condition, which I don't know.
I have already tried the RF module with boundary weak contribution to solve for E, but a similar problem occurs where a default boundary perfect electric conductor subnode is incorrect and can't be overridden by the boundary weak contribution.
1 Reply Last Post 21.09.2012, 05:17 GMT-4
