Surfate to evaluate temperature
Dear people,
is possible to define a surface where evaluate the temperature average after running simulation?
I try to explain better:
I have the result of a simulation made in university: my computer is too poor to run it. Now at home I must evaluate the temperature of a surface inside my object: is possible without restart simulation?
Thanks a lot. Bye
Roberto
3 Replies Last Post 18.09.2012, 14:48 GMT-4
Posted: 1 decade ago 17.09.2012, 14:01 GMT-4
I would say you need to define a cut plane orline or use an existing boundary and export that, then you can reload that into another software and analyse from there
Hi I would say you need to define a cut plane orline or use an existing boundary and export that, then you can reload that into another software and analyse from there -- Good luck Ivar
Posted: 1 decade ago 18.09.2012, 12:49 GMT-4
Thanks Ivar you are a magician!
Roberto
Thanks Ivar you are a magician! Roberto
Posted: 1 decade ago 18.09.2012, 14:48 GMT-4
I do not think so (that I'm any magician ;), but I'm sure if you read the doc a few times(more) and play with the models, then try to help others on the Forum, you will become just as "magician" as me ;)
Hi I do not think so (that I'm any magician ;), but I'm sure if you read the doc a few times(more) and play with the models, then try to help others on the Forum, you will become just as "magician" as me ;) -- Good luck Ivar
