Multilayer thin film
I want to create a multilayer thin film and want to put boundary (diffusion) condition at the interface between two layer. How could I proceed with that ? Any help would be appreciated
1 Reply Last Post 15.09.2012, 05:39 GMT-4
Posted: 1 decade ago 15.09.2012, 05:39 GMT-4
the easiest way to make thin layer, is to use the rectangle function and add "layers" in the specific layer node, one thickness per layer.
Then you apply your model BCs as needed
Hi the easiest way to make thin layer, is to use the rectangle function and add "layers" in the specific layer node, one thickness per layer. Then you apply your model BCs as needed -- Good luck Ivar
