Will COMSOL reset matlab global variable in each step?
I am doing parametric sweep in COMSOL v4.3. the COMSOL model is connected with a matlab funtion fun() which has a global variable G inside. Will COMSOL clear/reset this G for each parameter automatically? If not, How to set up in COMSOL to make sure that G starts with 0 for each parametric sweep input?
Thank you
Dan
2 Replies Last Post 04.09.2012, 21:16 GMT-4
Posted: 1 decade ago 04.09.2012, 20:11 GMT-4
I don't trust COMSOL working with global variables as I've seen it being inconsistent. If I need to reset global, I do it in the code. If I need to keep a variable, I define it as persistent variable.
Posted: 1 decade ago 04.09.2012, 21:16 GMT-4
Thank you.
In COMSOL v3.5a, I just run my model in matlab, and this global variable is not a problem.
When I update my model to COMSOL v4.3, everything just changes, I cannot figure out.
Today, I learnt how to obtain stiffness and load matrix from COMSOL 4.3, and how to use a linear solver to get result vector U. Do you know how to write this "U" back to COMSOL so that I can open the solution in COMSOL?
My model has parametric sweep inside, in comsol, those lines are:
plist = [fem.sol.plist nvec(ii)];
u_tot = [fem.sol.u u_end];
fem.sol = femsol(u_tot,'pname','n','plist',plist);
Do you know what command is equivalent to femsol() in the new comsol?
Thanks a lot.
Dan
[QUOTE] I don't trust COMSOL working with global variables as I've seen it being inconsistent. If I need to reset global, I do it in the code. If I need to keep a variable, I define it as persistent variable. [/QUOTE] Thank you. In COMSOL v3.5a, I just run my model in matlab, and this global variable is not a problem. When I update my model to COMSOL v4.3, everything just changes, I cannot figure out. Today, I learnt how to obtain stiffness and load matrix from COMSOL 4.3, and how to use a linear solver to get result vector U. Do you know how to write this "U" back to COMSOL so that I can open the solution in COMSOL? My model has parametric sweep inside, in comsol, those lines are: plist = [fem.sol.plist nvec(ii)]; u_tot = [fem.sol.u u_end]; fem.sol = femsol(u_tot,'pname','n','plist',plist); Do you know what command is equivalent to femsol() in the new comsol? Thanks a lot. Dan
