Remi Magnard
COMSOL Employee
3 years ago
30.09.2022, 03:30 GMT-4
Dear Michael,
See below a script that illustrates how to combine the solutions of two models using the COMSOL API in MATLAB:
% Load source model
model1 = mphopen('open_pipe_solve1','Model1');
model2 = mphopen('open_pipe_solve2','Model2');
% Load destination model
model = mphopen('open_pipe_solve1','ModelFull');
% Get Parameter list
PVals1 = model1.sol('sol1').getPVals;
PVals2 = model2.sol('sol1').getPVals;
% Construct thenew full list of parameters and set it to the source model
PVals = [PVals1;PVals2(2:end)];
model.sol('sol1').setPVals(PVals);
% Extract solution vectors in source models and set them in the destination
n = length(PVals1);
for i = 1:n;
U = model1.sol('sol1').getU(i);
model.sol('sol1').setU(i,U);
end
for i=2:length(PVals2);
U = model2.sol('sol1').getU(i);
model.sol('sol1').setU(n+i-1,U);
end
% Create the solution
model.sol('sol1').createSolution;
Note that you could also have both solutions available within the same model, in this case use the Combine Solutions study step to generate a new solution, see the attached model combine_solution.mph (the model solution is reset to reduce its size, so you need to run Study 1, Study 2, and then Study 3).
Rémi
Dear Michael,
% Load source model
n = length(PVals1);
for i = 1:n;
end
end
Rémi
