Passing Multi-Parameter Parametric Sweep Solutions as Initial Values
How do I pass solutions of a Parametric Sweep for Study 1 as the Initial Values to a Parametric Sweep for Study 2? In the attached CFD example Studies 1 and 2 have the same Parametric Sweeps for All Combinations of Uav and l (six combinations of inlet velocity (n=3) and domain length (n=2) respectively).
With a single parameter solved in the sweep, I understand this to be straightforward by placing the following line in Initial Values say for streamwise velocity component u based on inlet velocity Uav:
withsol('sol1', u, setval(Uav,Uav)) .
But how do I correctly tell Study 2 that it should be looking for the solution in Study 1 that corresponds to both parameters?
1 Reply Last Post 24.08.2022, 10:39 GMT-4
Hello Brandt
Posted: 2 years ago 24.08.2022, 10:39 GMT-4
I'll update this for others. Turns out this is fairly straightforward and can be accomplished with:
withsol('sol1', u, setval(Uav,Uav), setval(l,l))
I'll update this for others. Turns out this is fairly straightforward and can be accomplished with: > withsol('sol1', u, setval(Uav,Uav), setval(l,l))
