How can I create a 3D hexagon?
Hello, as the title implies I would like to build a 3D hexagon which is hollow inside. I am esentially trying to model a hex-mesh with an iron fillings solution. I am unsure about how to manipulate the work planes or geometry. Any help would be appreciated :)
2 Replies Last Post 24.03.2022, 15:33 GMT-4
Posted: 3 years ago 24.03.2022, 15:20 GMT-4
Updated: 3 years ago 24.03.2022, 15:26 GMT-4
A hexagon is a 2D shape. By "3D," are you referring to a hexagonal prism? E.g., https://www.geeksforgeeks.org/surface-area-and-volume-of-hexagonal-prism/ ? This can be made by drawing a hexagon in a workplane and then extruding it.
Posted: 3 years ago 24.03.2022, 15:33 GMT-4
Updated: 3 years ago 28.03.2022, 09:22 GMT-4
Assuming that you mean a hexagonal cylinder, then you can create one by drawing a hexagon in a workplane (See my old post here for how to easily draw regular polygons), then extrude it. Making it "hollow inside" is just a matter of creating two of them and taking the boolean difference.
If you are talking about a platonic solid (such as a dodecahedron), see this blog post on how to create one easily.
Jeff Hiller
Assuming that you mean a hexagonal cylinder, then you can create one by drawing a hexagon in a workplane (See [my old post here](https://www.comsol.com/forum/thread/157341/randomized-hexagon-using-model-methods?last=2017-10-17T21:27:02Z) for how to easily draw regular polygons), then extrude it. Making it "hollow inside" is just a matter of creating two of them and taking the boolean difference. If you are talking about a platonic solid (such as a dodecahedron), see [this blog post](https://www.comsol.com/blogs/how-to-use-the-platonic-solids-as-geometry-parts-in-comsol/) on how to create one easily. Best, Jeff
