Simulation of Moving Permanent Magnets
I would like to simulate two permanent magnets where one is fixed and the other is free to move. I am using the Magnetic Field, No Currents module to calculate the force on each magnet (like the permanent magnet example in the model gallery), and the Solid Mechanics module to apply the calculated force as a body load on the free magnet. I then would like to do a time dependent study to visualize the motion of the free magnet over time. However, there are several problems that I am having
1. The forces on the magnets vary widely in magnitude and direction with only small changes in setup (like mesh).
2. If I do a stationary mfnc study and apply the calculated force as a body load in a time dependent solid mechanics study, the free magnet will move according to the initial force on it. However, when I try to couple the mfnc and solid mechanics in a time dependent study, the solver will not run.
Any help would be greatly appreciated.
Thank you,
Shane
2 Replies Last Post 27.08.2012, 16:04 GMT-4
Hello Shane Lympany
Posted: 1 decade ago 27.08.2012, 10:27 GMT-4
can i see your model?
Posted: 1 decade ago 27.08.2012, 16:04 GMT-4
do not use the structural as you are doing a rigid body case, but use forced displacements () or velocity in the ACDC module. Then you should get forces out, but do not forget that forces are derived from the gradients integrated over edges, so these gradients are very mesh dependent
Hi do not use the structural as you are doing a rigid body case, but use forced displacements () or velocity in the ACDC module. Then you should get forces out, but do not forget that forces are derived from the gradients integrated over edges, so these gradients are very mesh dependent -- Good luck Ivar
