2 decades ago
06.02.2010, 05:15 GMT-5
If you operate in the "parametric solver" mode, you can define your "parameter" value as the frequency variable (or a value that drives the frequency though an expression)
Then you can scan over frequency or optical wavelength
2 decades ago
11.03.2010, 15:32 GMT-5
Hi!
What should I put in the "Global variable to evaluate" dialog box in order to get the effective refractive index as an output? I cannot find the name of the variable...
thanks a lot!
Francois
Hi!
thanks a lot!
Francois
2 decades ago
12.03.2010, 01:44 GMT-5
is it the "effective mode index" neff ? you are looking for
in which case try an indexed search on the rfug.pdf doc
good luck
good luck
20.08.2010, 06:07 GMT-4
hi dr
in photonic crystal and comsol v4, how can i plot dispersion?
hi dr
08.05.2011, 09:11 GMT-4
Hello Ivar
Plz tell us how we can calculate dispersion using version 4.10??
Thanking you
Regards
Anwar
Hello Ivar
Thanking you
Regards
Anwar
11.05.2011, 09:10 GMT-4
We didn't get the automation to work. In fact, we noticed that multiple modes showed up for each simulation point. We decided to go through each simulation point manually to choose the expected distribution profile. Many of the generated simulations did not make sense (lots of discontinuities), and we noticed that the generated results were very sensitive to our initial guess on effective refractive index.
I hope this helps.
Kevin
I hope this helps.
Kevin
