thermal strain issue
Dear Sir,
I've an urgent question about thermal strain simulation. Comsol simulates the thermal strain for two contact plates separately. I was wondering how to make the strain distribution continuous.
Please see the attached file and give me some suggestions. I'd really appreciate your help.
Elva
1 Reply Last Post 17.07.2012, 02:17 GMT-4
Posted: 1 decade ago 17.07.2012, 02:17 GMT-4
indeed you open an interesting question there ;)
You can also take a look at the Model Library - Structral - Thermal Structure Interactions - Layered Plate
If you add a boundary mesh layer on the internal interfaces you will also get steeper steps of the stress and strain
Question: are the steps in stress and strain physical or not ?
or should the strain be "smooth" across the boundaries ?
My first reaction is COMSOL is correct, but it doesn feel very intuitive and need some more thinking
Perhaps you get more convinced if you run a TS physics study on your model and increase the temperature gradually
Hi indeed you open an interesting question there ;) You can also take a look at the Model Library - Structral - Thermal Structure Interactions - Layered Plate If you add a boundary mesh layer on the internal interfaces you will also get steeper steps of the stress and strain Question: are the steps in stress and strain physical or not ? or should the strain be "smooth" across the boundaries ? My first reaction is COMSOL is correct, but it doesn feel very intuitive and need some more thinking Perhaps you get more convinced if you run a TS physics study on your model and increase the temperature gradually -- Good luck Ivar
