How to model plasticity problem in COMSOL if I have the true stress- strain curve?
I am modeling a nonlinear problem in which a large plastic deformation of a new alloy is to be done. As a material property of the alloy, I have the true stress-strain curve of the material and the young modulus of elasticity and Poisson ratio. How to implement the data of this true stress-strain curve in giving the material properties of plasticity problem with isotropic hardening in the COMSOL- Multiphysics 5.6?
Thank you!
1 Reply Last Post 27.01.2022, 14:48 GMT-5
Posted: 3 years ago 27.01.2022, 14:48 GMT-5
In this model https://www.comsol.com/model/elastoplastic-analysis-of-holed-plate-244 (also shipped in Application Libraries) you can find an example of how to use tabulated stress-strain data in an elastoplastic analysis.
The fact that your case is a large strain analysis will not make any difference. The expected input is true stress vs. true strain.
Henrik Sönnerlind
COMSOL
In this model (also shipped in Application Libraries) you can find an example of how to use tabulated stress-strain data in an elastoplastic analysis. The fact that your case is a large strain analysis will not make any difference. The expected input is true stress vs. true strain.
