Faisal Khan
Computational Fluid Dynamics
3 years ago
11.01.2022, 00:57 GMT-5
Updated:
3 years ago
11.01.2022, 01:01 GMT-5
Here is the attached geometry with broader left side boundary is oil inlet and narrower vertical is water inlet. I want to input the following formula in local variable as attached in jpeg 2. It is giving me unit syntax error. I am unable to understand where is the mistake. In attached jpeg 3, I defined the globlal variables and some dimensions of the geometry. L is the channel length (800 micrometer). Experts, please help me.
Faisal Khan
3 years ago
11.01.2022, 05:48 GMT-5
I believe its a unit warning, as COMSOL has issues with fractional powers of units. Try to set your logic expressions in "unitless values" of the type (x[1/m] < L[1/m]) if L is defined with units, else just drop the units for your "parameter " (?) L .
Check if that helps.
Note a unit warning is not considered as an error, and calulation will go on, but it is a potential error, so the results might be wrong ...
Sincerely
Have fun COMSOLing,
Sincerely,
Sincerely
Faisal Khan
3 years ago
13.01.2022, 01:02 GMT-5
Thank you so much Dr. Ivar.
Faisal Khan
