Modeling cracks
I'm brand-new to Comsol. I'm trying to model a pipe with a weld that does not penetrate through the entire wall of the pipe and runs the entire length of the pipe. There is a load being applied to the inside of the pipe.
I initially built a ring (using the difference between two circles) and then took another difference, between the ring and bezier polygon. This left a little crack in the pipe, as I wanted. But after adding the pressure (including to the bezier polygon surface), I realized that having the bezier polygon had no effect on the final results.
How might I be able to go about modeling this weld?
I'm trying to find the KI, if that's important.
challen
2 Replies Last Post 08.06.2016, 11:48 GMT-4
Hello Challen Herzberg
Posted: 9 years ago 07.06.2016, 11:34 GMT-4
Hi Challen,
I am also very new to Comsol and trying to model something similar but without the circumferential weld. Have you found a solution to this? If yes, please kindly share it with me. Thanks in advance.
Hi Challen, I am also very new to Comsol and trying to model something similar but without the circumferential weld. Have you found a solution to this? If yes, please kindly share it with me. Thanks in advance.
Posted: 9 years ago 08.06.2016, 11:48 GMT-4
This tutorial illustrates how to compute the stress intensity factor KI:
www.comsol.com/model/single-edge-crack-988
This tutorial illustrates how to compute the stress intensity factor KI: https://www.comsol.com/model/single-edge-crack-988 Best regards, Jeff
