Matt
Petroleum Engineering
3 years ago
31.12.2021, 08:37 GMT-5
Updated:
3 years ago
31.12.2021, 08:46 GMT-5
** Update, the solution seems to be to define an ODE with the following weak form syntax:
where u is a variable from another PDE/physics interface, and umin is the dependent ODE variable. However, this method only works for Time Dependent solver where derivatives are continuous. This will not work for Time Discrete solver in which time derivatives are replaced by bdf() operator. I wonder if anyone has a solution for time discrete solver?
\marthrm{0 = -d\left(umin,TIME\right)*test\left(umin\right) + \left(u\leq umin\right)*\left(d\left(u,TIME\right)\leq 0 \right)*d\left(u,TIME\right)*test\left(umin\right)}
Edgar J. Kaiser
Certified Consultant
3 years ago
01.01.2022, 16:23 GMT-5
Hi Matt,
have a look into this blog contribution by Walter Frei: https://www.comsol.de/blogs/using-the-previous-solution-operator-in-transient-modeling/
I have used this method in many transient and parametric studies. I think it should work in time-discrete as well, but haven't tried that so far.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Matt,
Cheers
Edgar
