Export Results of a Parametric Sweep
This topic has been discussed previously, but none of the solutions identified seem to work for my case.
I am running a 3D eigenfrequency model, solving for 20 eigenvalues (though COMSOL actually find 40). I am conducting a parametric sweep with 133 evaluations. I have 3 derived values I am resolving when the analysis is complete. My Data Set node solutions includes Solver 1, Parametric 2, and the 133 individual results.
I would like to export all of the results of the derived values from all the runs at once. I tried to evaluate the derived values using the Parametric 2 solution, but I continually get an error that states "Property solnum out of range." I can evaluate my derived values using any individual run solution, but that would require that I evaluate and export each one individually.
If I try to use the Export node with a data export, using Parameter 2 as the Data Set, I get empty file with just header information (no data).
Can someone recommend a way for me to export all of my derived values from my sweep at once. Perhaps a way to increase the range of solnum or work around this error. Or maybe a way to get the export to recognize all the results in the solution at once and export the data. Any suggestion appreciated.
Thank you,
Ian
0 Replies Last Post 04.07.2012, 16:04 GMT-4
Hello Ian Stern
