Robert Koslover
Certified Consultant
3 years ago
06.11.2021, 16:56 GMT-4
Updated:
3 years ago
06.11.2021, 16:57 GMT-4
What kind of "design" problem are you having? For example:
1) You don't know how to draw the geometry?
2) You don't know what physics/module to choose?
3) You don't know what boundary and/or symmetry and/or source conditions to choose?
4) You don't know how to choose/set-up the mesh?
5) You don't know how to tell the software what kinds of plots or tables of data you wish to generate/look at in post-processing?
If you describe your problem in more detail and with as much specificity as possible, then you are much more likely to receive helpful advice.
What *kind* of "design" problem are you having? For example:
1) You don't know how to *draw* the geometry?
2) You don't know what *physics/module* to choose?
3) You don't know what *boundary* and/or symmetry and/or *source* conditions to choose?
4) You don't know how to choose/set-up the *mesh*?
5) You don't know how to tell the software what kinds of plots or tables of data you wish to generate/look at in *post-processing*?
3 years ago
07.11.2021, 03:18 GMT-5
Updated:
3 years ago
07.11.2021, 03:20 GMT-5
I am not able to draw the triangular spikes (more accurate image linked). I dont know what geometry to use. I think a triangular wave using parametric curve will get the job done but I couldn't find a triangular wave equation that works in parametric curve.
https://drive.google.com/file/d/1deHwJYmBWbQ1VH6pe2u75pNQ3gAyoR79/view?usp=sharing
[https://drive.google.com/file/d/1deHwJYmBWbQ1VH6pe2u75pNQ3gAyoR79/view?usp=sharing](https://drive.google.com/file/d/1deHwJYmBWbQ1VH6pe2u75pNQ3gAyoR79/view?usp=sharing)
Robert Koslover
3 years ago
07.11.2021, 11:02 GMT-5
- Create a workplane.
- Draw your 2D structure, using the polygon tool.
- Extrude your structure into 3D.
I've attached an example. In the workplane, I used the polygon tool, the array tool, and the union operation.
1. Create a workplane.
2. Draw your 2D structure, using the polygon tool.
3. Extrude your structure into 3D.
I've attached an example. In the workplane, I used the *polygon* tool, the *array* tool, and the *union* operation.
