Robert Koslover
Certified Consultant
3 years ago
04.11.2021, 16:34 GMT-4
Updated:
3 years ago
04.11.2021, 16:36 GMT-4
The proper choice of physics and study depends on what you are trying to compute, not so much on what you want to plot. There are many possible studies and processes that could involve computing an "electric field intensity" in a "2d structure." So I encourage you to tell the community more about what kind of physics problem you are actually trying to solve. Finally, bear in mind that in any of them, if the electric field is computed, then you can plot it fairly easily using the post-prcoessing tools. To learn how to use those, refer to the many example applications, tutorials, videos, and more that have been provided by Comsol.
The proper choice of physics and study depends on what you are trying to *compute*, not so much on what you want to *plot*. There are many possible studies and processes that could involve computing an "electric field intensity" in a "2d structure." So I encourage you to tell the community more about what kind of physics problem you are actually trying to solve. Finally, bear in mind that in any of them, if the electric field is *computed*, then you can plot it fairly easily using the post-prcoessing tools. To learn how to use those, refer to the many example applications, tutorials, videos, and more that have been provided by Comsol.
3 years ago
04.11.2021, 17:54 GMT-4
The problem involves using metamaterials and passing an electric field through the material, for now , i have the electric field surface plot .
Robert Koslover
3 years ago
04.11.2021, 19:10 GMT-4
Updated:
3 years ago
04.11.2021, 19:11 GMT-4
Good. If I understand you correctly, then at this stage, you've solved your problem? You say you "have the electric field surface plot." May I assume that you made that plot using Comsol Multiphysics? If so, then I am going to guess that, at this point, you have learned enough about the "Results" part of the interface to similarly figure out how to make line plots. Note that if you don't already have the line of interest to you specified during the geometry-making stage, you can always add one after the FE problem solution, by adding a "cut" line. Best regards.
Good. If I understand you correctly, then at this stage, you've solved your problem? You say you "have the electric field surface plot." May I assume that you made that plot using Comsol Multiphysics? If so, then I am going to guess that, at this point, you have learned enough about the "Results" part of the interface to similarly figure out how to make *line* plots. Note that if you don't *already* have the line of interest to you specified during the geometry-making stage, you can always add one after the FE problem solution, by adding a "cut" line. Best regards.
