Parasitic capacitance of inductor
Hi!
How can one calculate parasitic capacitance of inductor? Is it possible in 2d axisymmetric case? I can't find any situable example.
P.S. I use AC/DC Module to model inductor.
Thank you!
3 Replies Last Post 12.11.2013, 08:18 GMT-5
Posted: 1 decade ago 22.06.2012, 06:00 GMT-4
its not obvious to know what you call the parasitic capacitance, as even the cabling come with extra C values to any model.
But in ACDC ES you can get the lumped capacitance of a complex model, and you can compare that to the results from a simple geometrical results, based on electrode shape and distance + dielectric constant,. but the latter you must calculate by hand
Hi its not obvious to know what you call the parasitic capacitance, as even the cabling come with extra C values to any model. But in ACDC ES you can get the lumped capacitance of a complex model, and you can compare that to the results from a simple geometrical results, based on electrode shape and distance + dielectric constant,. but the latter you must calculate by hand -- Good luck Ivar
Posted: 1 decade ago 08.11.2012, 18:52 GMT-5
simply plot a frequency/Impedance graph, and curve-fitting some capacitance and use 1/2piefc.
www.7pcb.ca
simply plot a frequency/Impedance graph, and curve-fitting some capacitance and use 1/2piefc. www.7pcb.ca
Posted: 1 decade ago 12.11.2013, 08:18 GMT-5
Dear Vladimir,
Did you find an answer to your question? Do you have any working example?
Thank you in advance,
Dima.
Dima Apter
A2Z Consulting Ltd.
www.a2z-consulting.com
[QUOTE] How can one calculate parasitic capacitance of inductor? Is it possible in 2d axisymmetric case? [/QUOTE] Dear Vladimir, Did you find an answer to your question? Do you have any working example? Thank you in advance, Dima. -- Dima Apter A2Z Consulting Ltd. www.a2z-consulting.com
