How to bond two panels together in simulating sound waves in the coincidence region
I am trying to simulate sound waves hitting two flat panels, which is build upon the Tutorial Sound Transmission Loss in a Concrete wall. I am trying to study the behaviour of the coincidence effect by modelling different panels. My model has 3 blocks, 2 of them are MDF panels and 1 is an air domain block with perfectly matched layers.
How do I set two 4.5mm thick panels to be "glued" together so that it behaves like a single 9mm thick panel?
4 Replies Last Post 28.09.2021, 23:03 GMT-4
Posted: 3 years ago 13.09.2021, 10:53 GMT-4
Hello John,
If the two panels are glued together so that they behave like a single 9mm panel, why not model them as a single 9mm block?
Jeff Hiller
Hello John, If the two panels are glued together so that they behave like a single 9mm panel, why not model them as a single 9mm block? Best, Jeff
Posted: 3 years ago 25.09.2021, 04:03 GMT-4
Hi Jeff,
It is because I would like to also simulate strips of glue bonding 2 panels together, not a completely bonded surface. The strips of glue would be thin lines running between the panels, and that is the setting I have trouble figuring out.
Cheers
Hi Jeff, It is because I would like to also simulate strips of glue bonding 2 panels together, not a completely bonded surface. The strips of glue would be thin lines running between the panels, and that is the setting I have trouble figuring out. Cheers
Posted: 3 years ago 27.09.2021, 11:24 GMT-4
You need to know the mechanical properties of the glue. The glue needs to be a separate domain (or domains). Since the glue is probably thin you may need to use a swept mesh to keep the number of elements from becoming prohibitively large.
Posted: 3 years ago 28.09.2021, 23:03 GMT-4
Hi Dave,
Thank you, that is a good suggestion.
Hi Dave, Thank you, that is a good suggestion.
