HP
Doctoral student, Uppsala University
4 years ago
08.08.2021, 03:01 GMT-4
I managed to give random motion to the sphere using moving mesh(ALE). But while it is moving in air, sphere does not take material properties(copper). That is it became air. Is it a problem in geometry or moving mesh (ALE)?
I used 'assembly' under the geometry .
Jeff Hiller
COMSOL Employee
4 years ago
11.08.2021, 10:51 GMT-4
Updated:
2 years ago
14.04.2023, 09:57 GMT-4
Hello Hasupama,
Typically, in an electrostatic simulation like this one, you do not include perfect conductors like your copper sphere in the computational domain. Rather, you remove them from the geometry, so that the electric field is only solved for in the region occupied by the dielectric (air, in your case), and you apply a floating potential boundary condition at the surface of the perfect conductor (thereby ensuring that it is at a single, though not known a-priori, electric potential).
You don't need to use a moving mesh as far as I can tell if all you want to do is run a number of stationary studies each corresponding to a different location for the center of the sphere. A parametric sweep will do. See the attached file.
Jeff Hiller
Hello Hasupama,
