Creating a small cylinder with changing refractive index
Hey there! How do you create creating a small cylinder with changing refractive index? For example, I would like to the refractive index to be with a Gaussian profile.
Thanks, Ivan
1 Reply Last Post 10.08.2021, 21:01 GMT-4
Posted: 4 years ago 10.08.2021, 21:01 GMT-4
One possible way: 1. Create a user-defined function for your Gaussian, under Component 1 --> Definitions --> Functions --> Analytic. For example, it would have the Arguments: x, y, z and could have an expression something like (just an example) 1+exp(-x^2-y^2-z^2) . That would be a Gaussian with a base of 1 and peak of 2, around zero, in a sphere. You'll decide what function you want for your cylinder, but to keep it simple, I suggest you put it in terms of x, y, and z. Give the function a name, e.g., myname. 2. Now go to Materials, and find the place where you specify either dielectric constant or index of refraction (which is related, but not the same thing, so be sure you understand that) and put your function in there, i.e., myname(x,y,z). That is, the software will allow you to put a function of x, y, and z under the material properties, rather than just a simple scalar! And that makes solving your kind of problem a lot easier!
I hope that helps.
One possible way: 1. Create a user-defined function for your Gaussian, under Component 1 --> Definitions --> Functions --> Analytic. For example, it would have the Arguments: x, y, z and could have an expression something like (just an example) 1+exp(-x^2-y^2-z^2) . That would be a Gaussian with a base of 1 and peak of 2, around zero, in a sphere. You'll decide what function you want for your cylinder, but to keep it simple, I suggest you put it in terms of x, y, and z. Give the function a name, e.g., *myname*. 2. Now go to Materials, and find the place where you specify either dielectric constant or index of refraction (which is *related*, but not the same thing, so be sure you understand that) and put your function in there, i.e., *myname(x,y,z)*. That is, the software will allow you to put a *function* of x, y, and z under the material properties, rather than just a simple scalar! And that makes solving your kind of problem a lot easier! I hope that helps.
